Hi Guys
Got a bit of a problem on my '72 twin slider I'm restoring.
Am investigating the sliding doors which don't really slide smoothly, sometimes jump off the runners and don't close neatly. So far I've found several bits that are missing (including a cam for one of the centre hinges (ITEM 18 on the diagram below) and the top roller for one of the front lower guides).
Luckily the cam is available from VW Heritage. I've swopped the one from the other side but am now having problems with the arm not swinging in/out correctly. It looks like the whole guide unit is too high and the hooked lever isn't being released from the cam so the arm won't swing in/out.
Once I get the 2nd cam I'll be able to compare the two together.
In the meantime though can people confirm which way round the levers are meant to face as mine are both different!
The diagram below clearly shows the top lever 21 facing inwards towards the nylon guide
My right-hand (offside) door has them this way round but on the left-hand (nearside) door they are round the other way with the top lever facing outwards! I have a spare guide which has the levers facing the same as the offside door but these levers are much more 'chunky'.
I've grabbed this photo from another topic on the forum and it clearly shows the levers facing the opposite way to the VW diagram!
on the other hand this one shows it the 'correct' way
ANY IDEA WHAT IS RIGHT??????????????
