Space Saver Wheel Query. Bunk Query. Indicator problem!!!
snaresbrook
Apr 20, 2008
9
South London
Hi, Im trying to save some space inside my 71 dormobile and wanted to get a space saver wheel if possible, but which ones will fit as I have 15 inch empis with 195/55 R15 tyres.
Also need a spare tartan bunk if you know of 1 going?
ps my indicator keeps blowing fuse turning left only, would this be relay, switch or something else?
Thanks for reading.
:D
Check if the fuse that keeps blowing is the main ignition one or the indicator itself. If the later check for earths or bare wires, in correct bulb etc from the indicator to the fuse box. If all Ok check from fuse box to stalk. It could be a lose/frayed wire in the stalk housing.
Never seen a space saver in Wide 5. Think you can get them for Porsche fitment but you didnt mention what PCD you have got (bolt pattern)
Good luck with finding the parts you need.
Any reason why you couldn't use a bolt pattern adapter on a space saver to take it to wide 5?
