Myvanway
Dont realy want to sell but it gets so little use and I have other things I want.
So here it is.
My 2010/11 Specialized Stumpumper Comp HT .
Its a work of art....As are all Specialized Bikes. 8)
Frame size is 17.5 (Medium) I am 5ft 11in.
It has been used to commute to work about 10 times and round Grapham Waters & Rutland waters a coupl of times.
Its MINT Condition.
Spec:
Frame: M5 manipulated alloy frame, curved TT, SS w/ disc brake mount
Fork: Fox Float F90 RL, 90mm travel, air spring, compression and rebound adj. w/ LO, alloy steerer
Head Set: 1-1/8" Threadless, 10mm insertion alloy cups, sealed cartridge bearing
Stem: S-WORKS Alloy/Carbon
Handlebars: Easton Monkey down hill sweep bars
Grips: Specialized thin lock on grip
Front Brake: Custom Avid Elixir R SL, alloy backed organic pads, 160mm rotor
Rear Brake: Custom Avid Elixir R SL, alloy backed organic pads, 140mm rotor
Brake Levers: Custom Avid Elixir R SL Hydraulic, tool-less adj. reach
Front Derailleur: Shimano SLX 34.9mm clamp, top swing, top pull
Rear Derailleur: SRAM X-9, 9-speed, mid cage
Shift Levers: SRAM X-7, aluminium trigger
Cassette: Shimano HG80, 9-speed, 11-32t
Chain: SRAM PC-971, 9-speed w/Power Link
Crank Set: Custom Shimano FC-M542, 175mm
Chainrings: 44A x 32A x 22S, 4-bolt, 104/64mm
Bottom Bracket: Custom Shimano, outboard bearing
Pedals: DMR Magnesium (BMX Style) Flat pedals
Rims: Custom DT Swiss X420SL, 24mm w/ eyelets, 28h/32h
Front Hub: Specialized Hi Lo disc, CNC flange, sealed cartridge bearing, 9mm DT RWS, alloy QR, 28h
Rear Hub: Custom Shimano M525 SL, alloy QR, 32h
Spokes: DT Swiss 1.8mm stainless
Front Tyre: S-Works The Captain, 26x2.0", 120 TPI, tubeless ready Kevlar bead, dual compound
Rear Tyre: S-Works Fast Trak LK, 26x2.0", 120 TPI, tubeless ready Kevlar bead, dual compound
Inner Tubes: Ultralight presta valve
Saddle: Specialized Phenom, hollow Cr-Mo rails, thin foam, 130mm
Seat Post: 2014 butted alloy, single bolt setback, 30.9mm
Seat Post Clamp / Binder: 7050 hard anodised alloy collar, 34.9mm clamp ID, black
Like I said Hardly used at all, an awesome ride and A beautiful piece of engineering.
I paid £1495 not including the stem, Bars & Pedals which were an extra.
£650ono.
PM Me if interested.
Paul.
£650 ono
Thanks for looking and if interested PM me.
Paul.
So here it is.
Its MINT Condition.
Spec:
£650ono.
Paul.
£650 ono
Paul.
