spot welder SOLD SOLD
hogseye
Apr 17, 2007
567
sunny suffolk
Clarke CW11T for sale hardly done any work, used it on my project about 7 years ago and been sat in corner of garage ever since. dusted it off today and tried it out with a couple of spot welds and still works perfectly. has a little surface rust on the main body on the top as it wasn't sitting in a box but if you look at pic from underside you will see how little used it is. will plug into a normal 13amp socket and will weld 1mm plus 1mm so will do most things you need it to do on a vehicle. It has a timer so you dont have to guess how long you have been holding it on, and adjustable pressure for the arms depending on what you are welding, also has a home made hook to support the weight if you are working along something like a roof gutter. only got the one set of tips that it came with again in great condition. I used this to get factory looking spot welds on the areas that are seen and where it is possible to spot weld.
collect from ipswich or can post £200 posted or £185 collected....
