Julesx
Can anyone help!? I'm new to all this :shock:
I have just returned from a 1000 mile trip in my bus which performed well until I was about 500 meteres from home. I suddenly found that I could only select 3rd, 4th and reverse gear.
I have done some searching and it seems that the shft plate needs adjusting??
I have just enthusisatically attcked this job and having left it in neutral I removed the two bolts and lifted the gear shift free. I have cleaned everything up but now find that I cannot get the ball at the end of the lever back in the hole in the shift rod under the van.
The problem seems to be the small pin that is in the ball part at the bottom of the shift lever. This is sprung loaded and will not allow me to locate the 'ball in the socket' as it keeps popping out.
How do you do this?! Do I need someone under the van to push the two bits together or is there a secret way of doing this?
