Starter motor stop ring broken help
thejinx
Mar 30, 2011
1,564
77
swansea
Took the starter motor off today to change the bush and found the Stop ring is cracked. Can't see where I would get one. Anyone know please or has anyone got one? Thank you. I don't want to buy a starter motor just because of that
Sorry MODs in my haste I didn't think and have put this in the wrong place.
On further investigation I have found a large amount of play in the spindle on the starter motor, it looks as if the bearings have failed. So what started out as changing a bush has turned into a new starter motor.
If it’s a genuine Bosch, you should be able to get it refurbished for less than the cost of a new one. Some places will do an exchange so could save you a bit. If it’s a Chinese copy then it is probably only good as a paperweight.
