I'm having some intermittant starting issues with my 1971 bay and currently it won't start, when you turn the key to the start position the dash lights dim but the starter doesn't turn. Now this has happened a couple of times before but after leaving it for a few days the problem resolved itself so I didn't do anything about it but now it's happened again I thought it's about time to get it sorted.
I assume that the problem is with the starter as the dimming of the dash lights indicate that there's some power drain when the switch is turned. Is there anything else I can do to verify that it is the starter motor rather than the ignition switch itself that's causing my starting woes? And, if it is the starter motor, any tips on replacing it? I assume the units the same as on a beetle?
