wilkie
Tried to start the van after about a month and it wouldn't turn over. Jump started OK. I put the battery on charge over the weekend thinking it was that simple but still nothing when I tried it this evening. I put a volt meter across the battery and took a reading of 13.6volts. Do you think this is a battery problem or should I look elsewhere? The battery looks old and I have a new leisure battery which I could try but was unsure if this could damage it.
Your advise would be gratefully recieved.
