Seeing as we're (hopefully) moving house soon, I've had to pull my finger out recently and attempt to get the van back on 4 wheels so it can be trailered to the new place.
A friend, Jeremy, had fitted a steering rack from a Bedford Rascal to his BaySplit and has started doing DIY kits to allow fitting to bay window vans. Having heard how much more 'modern' the van feels to drive with one of these on, I decided it was worth doing in the long run. So, this morning, we set up fitting it all up:
Reconditioned rack with universal joint. The bit sticking out the top of the UJ gets welded inside the old steering column
Chassis leg it prepped. The hole here has to be big enough to take the plate that has a captive nut welded on its back
Jeremy trial fitting rack
Plate TIG welded in place
Rack in place
Gives you an idea of the whole geometry change. Arm on the swivel/steering pin is custom made
Had to cut out some chassis sections to make room for the connecting arm
This was a morning's work, and having an inspection pit helped no end
If anyone's interested in having one of these mods doing, pm me and I'll pass on Jeremy's details. He's doing the kit for £450 + fitting if needed.
Right...I may have steering and four wheels now, but still need a gearbox and engine in,
brakes doing,
wiring, windows, pop-top.......
