thejinx Well-known member Supporting Member Joined Mar 30, 2011 Messages 1,559 Reaction score 73 Location swansea May 27, 2019 #1 As it states in the heading. I have read somewhere that to remove this I can remove HT lead and crank the engine to blow it out. Can anyone confirm this please? Cheers.
A atafonso Well-known member Supporting Member Joined Sep 7, 2016 Messages 440 Reaction score 0 Location Wrexham, Wales May 28, 2019 #2 Have you removed the screw and spring already and it did not fall? Cranking the engine might shoot the piston down and make a huge mess I use an M12 tap to grab them and with a little twist they normally come out Abel
thejinx Well-known member Supporting Member Joined Mar 30, 2011 Messages 1,559 Reaction score 73 Location swansea May 28, 2019 #3 Cheers. I have removed the screw and spring and had a good wiggle but it is well stuck. I will get an m12 this weekend. Cheers
