aircured
I have just had to removed a damaged front shock absorber, which meant replacing both front shox.
I removed KYB Gas-a-just (KG452)......Then replaced them with KYB GR2's (eye/eye).
Went for a test ride and there didn't seem to be much difference. :shock:
The question is, will they be ok, as I noticed that the bolt fitting sleeves were slightly longer on the new shocks.
or should I again change them back to Gas-a-just.
Not sure what to do, as the van had already been slightly lowered by PO.
