Weather not suited to my pale complexion [emoji23] But it has made us both realise how we miss having the calendar full of shows etc... gutting as one by one event after event has been cancelled.creationblue said:Van looks great, reminiscing over CJ 2018, the weather the football, great times
They look great!And as if by magic, the finished effort:
Obviously the drivers side has a mirror-image one! I knocked up a few brackets using some aluminium strip that I may paint black to blend them in a little better with the dash area. I didn’t want to be drilling holes all over the place to mount them, so two of them pick up on original bolts, and the only ones I had to add was on the handbrake support bracket.
Handy for chucking the wallet and shades on!!
The twine was the most expensive part, it is 1kg of 3mm unpolished flax twine and with postage was just under £30. I didn’t use the full reel, but certainly used more than half of it. The MDF was just from some 19mm off-cuts I had lying around, but probably less than a tenner. And then the tee nuts and Allen bolts were probably no more than a fiver from Screwfix.looks good to me
How much did they set you back in the end?
