starbiscuit
Just wondering if anyone has any tips for separating the two pieces of the linkage that run through the chassis rails?
The inner end, near the master cylinder (1970RHD bus) is OK, but the outer end that connects to the forward-going link rod has worn its hole to an oval. Lots of slop. It absorbs quite a lot of pedal motion without opening the throttle at the carb.
It seems the two shafts are joined by a roll pin, but I cannot shift it.
After ages bashing it (and my fingers) with hammer and drift I gave up. I just can't hold it steady enough and get enough of a whack on it to make any progress
Any ideas would be great.
Thanks for reading.
Thanks for reading.
