Eeza
Gents, I got hold of an SVDA dizzy and blasted an Accuspark kit into it just before Christmas, I set the timing using the static method but have now got a timing light (strobe thingy).
My engine is a not an OE bit of kit and so the pulley is probs not original and has timing marks that look like TDC, another mark 180 degrees from TDC and a cut on the rear face of the pulley marked with white paint that looks about 30 degrees to the LEFT of TDC as you look at the pully (ATDC ????) (This would be right for a 009 Dizzy)
Question is where should the timing be for this Carb / Dizzy combo
Vehicle starts fine but having been out for a blast it needs some adjustment (Feels Flat)
Any Ideas on the following :
Setting the 009 Centrifugal Advance, Single-Vacuum Dual Advance (SVDA) and Vacuum-Only Distributors with a Strobe -
The approximate idle timing setting for the centrifugal advance distributor (009), the single-vacuum distributor, and the vacuum-advance only distributor, is 7.5o Before Top Dead Center (BTDC). This means that as you view the 7.5o mark at the crankcase split (with the strobe), the TDC mark on the pulley will be about 11.5mm to the LEFT of the crankcase split when the distributor is properly timed.
Again, this is the APPROXIMATE timing setting at idle. once thats set go for the 30o setting at 3500rpms ?
