lard
I've been slowly getting my bus sorting out and now have all the components ready,
It's a 1600 TP and I've fitted a new carb, replaced alternator and since adjusted valves all round, checked & adjusted spark plug carbs, a compression check shows all around 125 -130
The only thing I haven't worked out is the timing and think this is causing the stuttering I'm having under acceleration
Went into a local garage when I first got it (haven't got a strobe yet!) and the guy reckened it wasn't far out and was set to 7 degress...( :?: )
My brother was down this weekend and putting his strobe on showed that the timing notch was showing behind the crankcase split (to the left) ...the pulley also only has one notch on it and a painted line to the right of this - checked timing with gun and the notch and line are both quite far to the left of the crankcase split..?
(forgive my vagueness...timing isn't my strong point!)
thought we'd check Muir/Benson to see what the timing should be on my engine and this is where the confusion came in - the engine number (stamped under the alternator pedestal) is 5545 AD 34166 - I can't see this in any of the tables?
It's running a vac dizzy with the number stamped on it starting "0231" - again, can't find in the manual's to see what the timing should be?
Any one offer any help with this? It's a 1971 bus but obviously not the origanol engine (as doesn't have the 71 manifold e.t.c.) and at a loss as to what the timing should be
Setup the new carb to idle at 850-900 and it's idling rough at the moment (not a steady idle) - with hesitation/missing under all acceleration unless at high rev's in the gears
It had this hesitation before I changed the carb (but now doesn't leak fuel...which is nice!)
shot of dizzy if that helps:
and engine (I've since changed the air cleaner to correct year one)
Just wondering what the timing should be set to and then I can have another go at setting the carb - at the moment I'm thinking that no amount of carb tweaking will be worthwhile until the timing is known to be correct?
any help identifying the engine and dizzy combo would be appreciated!
thanks,
larry
thanks,
larry
