Ben Thomas
- Joined
- Jul 26, 2007
- Messages
- 12
- Reaction score
- 0
Advertising for a friend as he's a Northern Monkey that cant drive his 'puter!!! Call him if interested.........here's what he had to say
....with great regret (best laid plans and all that!!!).. im having to part with my 'Tischer'....probably the only one in this country too!!!...Made from the 60's through to the late 70's as far as Im aware it sits perfectly on the back of a s/cab pick up and bolts on with adaptors that fix where the side gates fit normally...its a big 'un and sleeps 3 easily inside..one or two littluns over the cab and a good sized double bed when the table is dropped and the facing seats are used!!.....it has an elevating roof so standing up is no probs....also has cooker/sink/fridge etc and a small seperate bathroom at the back!!...fitting a shower or portaloo wopuld be no probs..theres loads of cupboard space inside too...theres space to fit a decent sized calor heater too with the correct vents all in place!!...its well useable as it is but could be tidied up as you please...all the fittings and fixings are there as far as Im aware!!!...outside its ok...a couple of dings but no probs...theres a small hole where one of the corner poles was obviously released too quickly and shot straight up...not done by me I might add!!!...it only takes a couiple of mins to elevate off your pick up then you can drive about as normal until its time to go!!!...pix to follow asap!!...Im after £1450 for this rare beast!!!....Cheers Andy 07939647317...Im in Souith Wales 2 miles from the end of the M4....youd need a pick up (obviously!!) or a trailer and something to strap it against to collect!!!
