- Joined
- Oct 26, 2010
- Messages
- 3,247
- Reaction score
- 17
- Location
- Leeds
- Year of Your Van(s)
- 1971
- Van Type
- Panel
So over the last two days I've been trying to sort out some stuff on my front suspension but at the moment I wish I hadn't bothered.
I finally got it back on the ground this afternoon and this is what it looked like
If I take the ARB off I am still only an inch from the floor (if that).
Previously it had been lowered on welded spindles.
I swapped these over for THaus 3.5" dropped spindles.
To have put me on the ground I can only surmise two things:
The more I've thought about it the more I think it is the latter.
Any ideas?
The purpose of the swap is that I need to narrow my track a little. After measuring a few things up I believe the THaus spindles will give me around 4mm extra tuck on each side (not to mention the ability to have a speedo cable fitted). This coupled with some new wheels I hope to have sourced this will give me the clearance I need.
I can reverse the procedure but I am worried that if the problem is with the leaves or something then I will still have the same problem. I am on a pretty tight schedule to get things done...
Any thoughts?
- Beam leaves have died... although there's definitely some tension on each trailing arm (or it would have been a breeze to fit the spindles).
- Beam has been cut and turned in a former life.
Any ideas?
Any thoughts?
