Twin carb fuel pipe location
montypsx
Jul 7, 2011
510
2
donny
Hi all I’ve got twin carbs on my bus and whilst I’ve got the engine out I want to run the fuel pipe behind the tinware to make it look neater.
Where do you run yours and what do you fasten it to please do you use cohline fuel pipe or metal with cohline at either end thanks Phil
What type of engine? Is the fuel pump stock?
Sent from my SM-G975F using Tapatalk
Sorry for the lack of info my heads a shed as usual. it’s a 1641cc with a standard fuel pump pal
Here's a few pics of mine passing through a hole to the left of the firewall, people also pass through the tinware using a preformed metal tube to prevent rubbing/chaffing of hose as it passes through
montypsx said:
Thanks for the pics it really helps [emoji106][emoji106]
No worries, happy plumbing [emoji106]
