Evening folks,
I’ve (yet again) got our engine out to cure an oil cooler seal leak, that has manifested itself recently by spraying a reasonable amount of oil around the engine bay during the hot weather. The lower two seals were weeping when we bought the bus, and I subsequently changed them a few years ago. Unfortunately, they continued to weep.
So either I’m doing something wrong (sealant type perhaps?) or I’m victim of poor quality parts.
Firstly, this is the cooler mount upon removal a it is pretty clear to see where the oil has been escaping from the right hand side of the right hand seal as looking at the photo (the yellowy stuff is the non-setting sealant that has weeped from the seals):
Secondly, this is the imprint that the seals have made on the block (one is quite offset) and of the port on the mount that seems to be causing the issue.
To those that are familiar with these, does the mount look normal? The oil way being at an angle I guess can’t be avoided, but the machining doesn’t look very central, and I think a combination of both these things is causing the seal to distort when torqued down and therefore leaking oil. I’ve no issue with buying a new one, but if they all look like this then I’m wasting my time and money!
Any pointers welcome!
