About a month ago I got the 2,0L type-4 running. It is a GE case with late type-4 (Vanagon) heads. Equipped with a pair of 38mm Solex PDSI's from BMW 2002.
When I first started it a month ago it run great. Even on idle.
Now it has been sitting outside since that weekend...
I have switched the fusebox on it since as I had a bug fusebox partly connected just to get it running then.
Now it seems like the battery is tired when I try to start it and when I finally get it started it first runs ok, but pretty soon starts shooting in the exhaust and run bad..
Can this trouble have something to do with the electrics and the fusebox switch? I'm not an automotive electrician so I might have got something wrong.
Before the oilpressure indicator did light up with the ignition on and shut down when it started. Now it dont light at all but an indicator lamp for brakeshoes burns all the time...
Maybe a burned condensator?
I dont know..
Anyone got any idea where to start?
The engine have hydraulic lifters and the rockers were adjusted when I had it running a month ago.
I dont know..
