surfbus
YEAH, stick with Porsche! :mrgreen:
uber cool said:stripped the carbs and all look fine. Fitted them, fired up the engine and it purred on all 6 straight off :mrgreen:
One bank of carbs is still sucking fuel in when turned off, so suspect the float height is not set right. At least it more promising than it has been before and I haven't even set the idle mixture and air bypass.
Then the fun beings, if you thought tuning 1 carb was bad I need to do 6, then balance them to each other. :shock:
uber cool said:I've struck gold on ebay again :mrgreen: Marelli uber rare dizzy including cap ( you cant buy any of this new, not even caps) all for £16.50 plus postage.
Also found a porsche 911 write on tuning triple webers (the zenith is very similar), so off to the garage tonight to have a play with the carbs and probably annoy the neighbours with endless revving :mrgreen:
uber cool said:Yeah 2.2t
uber cool said:Also found a porsche 911 write on tuning triple webers (the zenith is very similar),
