VDO Quarz Zeit AKA clock
MrApollo
Active member
Apr 30, 2019
29
I've got a VDO quartz clock that is running at almost exactly twice as fast as it should. They say time seems to go faster the older you get, and maybe this is proof, but is there anything obvious that would make the clock run twice as fast as normal?
That was my first thought, but it says 12V on the back of the clock, and I measured 12V across it. The little light is wired in too and works when the headlights are on. So all seems correctly wired.
Here's an image of the back of the clock, which screw would you try first? Its the black dial clock, which I've read was from '75 - '79. Thanks
