Wanted - Fog light switch
I have a Hella switch, it has a green lense to indicate when the lights are on, it's a period switch, £22 posted.
Ron
Thanks Ron.
I want to look a while longer for an actual fog light switch.
If I don't have any luck then I'll get back to you.
Cheers.
Don't hold yer breath. I posted for a bay fog switch about a year ago and still no replies.
Sent from my SM-A320FL using Tapatalk
Here's a couple but they're not cheap:
https://www.thesamba.com/vw/classifieds/detail.php?id=2051464
https://www.thesamba.com/vw/classifieds/detail.php?id=2044214
If I'm right there is an alternative.
I believe that the switch is common across a few applications- HRW for example- so you could buy one of these and a fit a new insert:
http://www.bus-ok.de/Type2-bay-fog-light-insert
which shows the other bits you need at the bottom of the screen
OK 25 euros for an insert is pretty rich but it's probably specially made....
The fog light switch has two positions, first is for front fog and second is for rear, the light also only illuminates in the second position
Think there is one on Ebay
http://www.ebay.co.uk/itm/Hella-Fog-Light-Switch-/132243520442?hash=item1eca53fbba:g:RjEAAOSwwzhZVLIE
same one as Busman73 describes
bit expensive, i found one at one of the VW shows for a tenner
