super-craig
filled the washer bottle up on the 68 and put 40 psi in it , and i ended up with a big puddle under it :shock: checked the tube for leaks and found a small split about 2 inch from bottle outlet , so snipped it off and put it back on , filled up again and 40 psi in bottle all well 8) well for 20 minutes anyway :shock: water started running from under nearside door (lhd) and from under the dash around the ignition switch :shock: dried it all off with an hair dryer for an hour , checked if all was ok and found the hazards on front only flashed on offside but when on indicator it flashed , so i presume the relay may have got wet and shorted , so with everything ok apart from the hazard problem i went out in it , it all worked ok until i wanted to start it again , all the lights came on dash but wouldnt start , no click or anything , not sure wether its down to the ignition switch getting wet or a sartter motor problem :? after an hour or so we tried to move in on to road and bump it down hill , we rocked it ready for moving it , but decided to try the ignition again , the thing fired up :shock: 8) :?
