Vancam70 said:could you use threaded bar and a tube nut for adjustment ?
Vancam70 said:chad said:I've had a look and have both types of bar and the flaps themselves along with the 'hook' that attaches to the thermostat. I may also have a used thermostat and bracket.
How much are you wanting for them ?
:mrgreen:atafonso said:Craig, you have put a lot of effort in your solution![]()
atafonso said:One thing though; where is the spring? The spring has to be installed as if the stat fails, the flaps will be open.
atafonso said:I can borrow you a bar and when you succesfully copy it you can send it back to me
Abel
chad said:Vancam70 said:chad said:I've had a look and have both types of bar and the flaps themselves along with the 'hook' that attaches to the thermostat. I may also have a used thermostat and bracket.
I'll do some pics first so you can see what you would be buying
