Dean
- Joined
- Feb 11, 2009
- Messages
- 217
- Reaction score
- 0
I have fitted twin 34 icts on my 1600 sp. I changed the idle & main jets and fitted the carbs after careful balancing. The carbs are correctly installed now and the bars etc are adjusted spot on.
I drove it for the mot last week and it's not right. The timing is spot on the plugs are fine but it's flat. It just seems to lack power. I can get 55 downhill with the wind pushing the van. It doesn't overheat, backfire or anything else visibly noticable.
I spoke to eurocarb today about upgrading other jets in the carb but they said it was probably more likel to be over fuelling killing the spark at high revs and at idle causing it to run faster than it should.
I've heard/read about the standard fuel pump(which i have) delivering too much psi in the fuel pressure dept and a regulator is needed.
So can people with/without fuel regulators help me out here and try to sort this problem out?
Dean
Dean
