I'm just fitting EMPI HPMXs to mine, (basically copy of the Weber IDF) and they have a port each for Vacuum. (I thought I was going to have to get a couple of connectors to thread into the ports, but they are the port that sticks out with a cap in the end, just unscrew the cap, and slip the vac tube on) Although, the vac port only seems to be drilled into one of the throttle venturis on each carb. I'm running the 123 dizzy with vacuum and don't want to go to the expense of changing for the non vac one, so, I'm going to give it a try on only one of the vac ports, and if it doesn't have enough, i'll tee the two together and see what that does.
I've been researching this a lot just lately, and there seems to be lots of contradictory info out there, with some people drilling their manifolds to tap from. (I've even seen someone take a drill to the carbs and put 4 vac ports in) I personally don't want to go down that route, and, from what I've read, the vac should be taken from just below the throttle butterfly anyway, which is where the port is on the IDFs.
As soon as I get my engine run in, the first place it will be is on the rolling road to tune the carbs up. (put a new cam in, so the first 30 minutes will be spent 2000 - 3000 rpm to bed the lifters in)
Hopefully, it will be done in a couple of weeks, so will update once I have a working solution.
Mark
