The pics are from an Irish forum apparently, some guy paid 9k for a bus, and posted up some pics to get advice on! :?
Clem said:The pics are from an Irish forum apparently, some guy paid 9k for a bus, and posted up some pics to get advice on! :?
the councillor said:like sinbad blowing up ron dicko's house with his jarg cooker
Clem said:It was more than that, man, it was the parade! And, think of the distress that Lindsay Corkhill went though ..... :evil:
Johnny said:anyway back on topic: welded spindles
i'snt most of the baywindow held together with welding? :wink:
Johnny said:its bad, very bad im not sure you would want to see it you might scream very loudly :lol:
first pic: looks like someone cut, sorry i meant butchered a square out of the spring plate in an attempt to notch it, without removing it first. Huge gouges left by the grinder and the angles sharp and unsquared, a definite reciepe for failure.
second/third pics: the end plates are the smaller bolt pattern and dont fit the later bus, the beam is only held by two bolts each side and the nut on bottom shock bolt is sitting below and underneath the chassis rail, a big pot hole and it could sheer :shock:
Evilben said:Then the answer is simple, if you want your bay nice n low then it has to changed to king and link pin loads more movement and loads safer :!:
then again your front bumper will go under the car in front, bye bye front panel, bye bye legs![]()
