Pretty sure I have a table , not sure about the legI got it completely wrong. It's the flip table he needs, not the sink table.
And yes with all the bits, hinges and leg.
His van has been at the bodyshop for 2 years and he finally got it back but they lost the table in the process.
Laminate comes off fairly easily if you heat it with a heat gun or use a cloth and an iron. Pry gently with a broad blade while you're heating it.That flip table…is a big pain in the keister.
One side of the hinges is glued into a slot in the plywood. It probably should have screws too, but you have to remove the laminate in order to install screws. The laminate objects to being removed.
This was not a problem for 50 years or so, but that was before my fat dog jumped up on the opened table in order to “rescue” a burrito. My attempt at a repair was clearly amateurish.
NLAVW sells all the parts, by the way.
NLAVW link to table
Clearly, I didn’t fully obey the word “gently” in its entirety. I will shortly be spending £99 at NLAVW.Pry gently with a broad blade while you're heating it.
