where can i get a new or re-con wheel shaft ?
hippysteven
Apr 23, 2009
167
hello , i was rebuilding the rear brake and wheel assembly on my 70 bay and i noticed that there was abit of wear on the wheel shaft , so i carried on and replaced the wheel bearings and seals , put everything back together and there is still abit of play in the wheel when i rock it top to bottom , so i now presume that it is the wheel shaft that is causing the problem, but after looking on the internet for a new one , i cant find one , does anyone know where i can buy one , thanks
Item 22 VW Heritage..............
http://www.vwheritage.com/vwh/VW-Camper-Van-Parts%5CBus-Parts-1968-79%5CSteering-Suspension%5CRear-Suspension%5C?templateID=vwh" onclick="window.open(this.href);return false;
There is supposed to be a little play on the rear wheel bearings. If they are tight when cold they will run over tight when hot and wear out very quickly.
i noticed that on mine, a bit of play and was considering replacing the bearings. I think i'll leave them alone, if it aint broke dont fix it?? :roll:
I made the same mistake many years ago, replacing the rear wheel bearings only to discover the new ones had the same amount of play -and then looking up in the manual to see the tolerance is correct :lol: The standard amount of play is quite noticeable and I seem to remember somewhere about 1.5mm or so at the rim cold. If the bearings are worn they will make a noise thats hard to miss.
hi thanks for the replys , its made me feel better haha, the only thing is the bus will be going in for the MOT soon and i dont want the tester to fail the bus on to much play in the wheel , i have replaced the innner and outer bearings and seals , and it still has a noticeable amount of play. so not sure what i should do :(
