Which Twin Carb Kit, Exhaust, etc for 1776 engine
RoddyLF
Feb 28, 2015
19
I am getting a 1776 engine from the VW Engine Company for my 1968 van.
What are the best upgrades to add to this engine:
Twin Carb kit upgrade?
Exhaust (preferably stainless steel)?
Coil?
Distributor?
etc
Sorry if this has been asked before but I am confused between all the differen t options available.
36 DRLA's if you can find them...
OR Weber 40's which are easy to get hold of:
https://www.vwheritage.com/shop/AC129K1317/weber-twin-40-idf-carb-kit-t1-2/" onclick="window.open(this.href);return false;
Eurocarb usually have Dellorto 36's in
http://www.dellorto.co.uk/merchandise/products.asp?CategoryID=26&PartsectionID=116" onclick="window.open(this.href);return false;
Thanks - the Dellorto 36's sound great - will read up further but definately on the list.
I literally just spotted these on ebay!
http://www.ebay.co.uk/itm/251863452975" onclick="window.open(this.href);return false;
Great spot. Just trying to weigh up cost of buying these DRLA's, then buying the kit against buying full kit including recondition carbs.
Those eBay carbs would need new chokes and jets to your engine spec, at least £100 + worth new, bear that in mind if you get 2nd hand Alfa carbs. By the time you get linkage, manifolds and filters too you'll prob wish you just bought new set jetted to suit.
I speak from past experience :roll:
After doing the sums came to the same conclusion as Dave.P. Will go for reconditioned kit.
Coil?
Distributor?
etc
Carbs I think your ON!
Exhaust:
https://www.vwheritage.com/shop/AC251816/vintage-speed-sports-exhaust-system-t2-68-79-std-tail-pipe/?crumbStartPage=1&crumbStartRow=1" onclick="window.open(this.href);return false;
Dizzy:
https://www.vwheritage.com/shop/AC905D186604/pertronix-cast-distributor-009-style-with-ignitor-i-12v/" onclick="window.open(this.href);return false;
Coil:
https://www.vwheritage.com/shop/AC90540511/flamethrower-i-coil-12v-black-3-ohms-socket-conn/" onclick="window.open(this.href);return false;
Leads:
https://www.vwheritage.com/shop/905QHT015BOSCH/ignition-lead-set-1-2-1-6-bosch-super-premium/" onclick="window.open(this.href);return false;
1776cc I would run external cooling and filter on:
Is your engine coming tapped for full flow?
https://www.vwheritage.com/shop/AC117308410/bugpack-cooler-fan-kit/" onclick="window.open(this.href);return false;
