halfpint_fighter
I noticed at volksworld my oil leak has got pretty bad. I reckon it is the flywheel oil seal as it is where the engine and gearbox join.
When we got home i looked underneath and it was dripping every few seconds while the oil was hot and thin.
I'd rather get on it soon so as not to wait until total failure and a ruined clutch plate.
So any other suggestions of jobs while the engine is out?
So far i have decided.
Gearbox oil change.
Obviously will the engine is out i might as well service (new spark plugs, Oil strainer etc)
Wire up reverse lights
Fit new tail light assembly (have done one side already, the plastic is brittle)
Need to fit 2 new heater cables
Fit the metal petrol pipe and rubber gromit as it doesn't have one at the moment.
Might look into modifying the engine support bar and fitting a full flow adapter on the oil pump (one which is a send a receive cover so as not to have to drill and tap the case!)
I have undersealed around the engine bay when the engine was out last year.
Gearbox oil change.
