so I ive been trying to get a new lift channel and rubber fitted to the van drivers window. In principle it’s a simple task in reality it’s Uber frustrating. Any tips please.
If you think you’re at last chance saloon with this window lifter . Would it be possible to get some glue down in there such as Gorilla glue, the type that expands a bit to fill the gaps and that’ll possibly hold it all together while you give it its last tap.I think I may have messed about too much with the lifter now. Opened it closed it possibly mullered. I will give it another go at the weekend. I changed My other one a few years ago and had no problems
I have started but decided against it.Don't open up the channel and try and 'crimp' it back on the glass. I did that, but only once.
A good thought. I may need toIf you think you’re at last chance saloon with this window lifter . Would it be possible to get some glue down in there such as Gorilla glue, the type that expands a bit to fill the gaps and that’ll possibly hold it all together while you give it its last tap.
Ozziedog,,,,,,,,, I use it on loads of stuff.
This was my solution, mine were soo tight. These Sash clamps sorted it. Slowly slowly
View attachment 6745View attachment 6746
That is some serious heath Robinson stuff there. AwesomeThis was my solution, mine were soo tight. These Sash clamps sorted it. Slowly slowly
When they are sitting there on site and you can use themThat is some serious heath Robinson stuff there. Awesome
