windscreen wipers not working
est gower
Mar 26, 2010
65
:( any body know how and why my wipers have just stopped working and how if i can fix the problem,not a mecanic but will have a go if poss?thanks if any one can help?too many wires and fuses!estelle
Hi!
I had the same problem, always in the rain, found a blown fuse, replace, and shortly after did it again, by this time the rain had nearly stopped.
I then found if i wiggled the fuse box it would work, there was a dodgy wire in the back of the fuse box, rewired it at the side of the road, no more problems, still working. I think the original brass terminals age harden over the years and the work loose or break when you wiggle them
Hope this helps, it may just be simple as fuse or loose wire
Alistair
:D thanks for your help will try that in morning ,have to start trying to fix problems myself or be broke thank you estelle :p
Hiya est,
Wipers can be tricky.
Generally speaking when any "device" suddenly (and suddenly is the key word here) stops working, the cause is almost always electrical in nature. Pull the plug and the device simply stops. So, I'd definitely agree with the above postings - check fuses and contacts.
But also know this.............wipers can stop working in short order due to friction in the pivot shafts. This stoppage may not be as abrupt as no electricity, but such stoppages can be darn to close to happening "suddenly". What happens is this.......... the shaft that your wiper blades are bolted to runs through a hollow brass shaft. This is the wiper pivot shaft. It needs to be well lubricated in order to allow the internal shaft (the one the wiper arm bolts to) to move freely. If the lubrication inside the wiper pivot shaft is not attended to on a regular basis the internal shaft can bind up solid.
Should you find no electrical reason for your wiper stoppage, go to Plan B and check to make sure the pivot shafts are well lubricated.
