Ponvanman
Active member
I have a 1968 model early bay. After being told a number of times I had a wobbly rear wheel I thought i'd investigate. I held a straight edge against the back tyre to discover there was around 5mm variation. I tried another wheel to rule out the other one being buckled and the same happened. I removed the wheel and tried a straight edge against the brake hub and again there was a 5mm variation. Is it possible that brake hubs can warp? Has anyone else experianced this type of problem?
