Wide 5 tyres
sunnyside
Nov 20, 2019
72
62
Hi guys,
Looks like I need x2 new tyres on my early bay. It has standard wide 5 steel wheels which currently have Nankang 205/70/14 tyres. What size tyres do you guys run on your standard steel wheels? My local tyre place can only get budget tyres in this size.
Thank you
Andy
I’ve gone with theses Maxis WormDrive 14 s for mine. I’m loving the look and I’ve quite successfully manouvered in mucky places where others with modern vehicles and tyres needed a bit of help either pushing or towing. It just could be that I’m a far superior driver being a professional driver and all that but I sincerely doubt that is even remotely possibly true. My van is fairly well insulated although not as quiet as something more up to date so it’s not a noisy old thing even with the vintage speed zoorst, but if there is any increase in tyre sound then I’ve really not noticed it. As far as mileage goes, I’m less than five thousand miles a year with my insurance and I’m really just under that and do about three to five thousand a year. Bays don’t seem to eat tyres unless there’s a fairly serious issue with alignment so I’m assuming that I’ll get five to ten years from these by which time I’m more than happy to get another set the same which is fine by me. Nowadays you can order your tyres on line and at the same time make arrangements for a delivery to a local tyre fitters shop for fitting. Might be worth checking prior to be sure they can fit and balance if possible as some have issues with their equipment not really playing nicely with wide fives.
IMG_3120.jpeg20230917_111608.jpegIMG_4264.jpegOzziedog,,,,,,,last one is current guise :)
View attachment 8891View attachment 8892View attachment 8893Ozziedog,,,,,,,last one is current guise :)
Love the centre caps
Funny you should say that. I really liked them and when they arrived I wasnt too sure. Then some days I’m thinking ‘Hell Yeah’ that’s different and I lovvvvvve it. Other days I’m thinking Nnnnnnnyaaa don’t know.
Ozziedog,,,,,,,,,,staying till the next brainwave overload :)
Well, you know what’s awesome about that? You can knock ‘em off and on as you feel 😉
I went with nexen 195 40R14c tyres from National/Halfords. These are 8 ply with a stiffer sidewall in the hope that they might help in crosswinds. They might be helping in crosswinds (difficult to say without stopping and changing onto other tyres), but they do help with rolling resistance. Much easier to psh the van into the garage now. I too bought buttys adaptor. Halfords came to the house and changed the tyres on the drive
If you are using 40-Series, 195/40 R14C tyres (assuming such a commercial-van tyre-size exists!?!) with a 40% aspect ratio, on 14 inch diameter wheels, the overall engine gearing will be radically changed as will the speedometer calibration. Unless the vehicle's speedometer has been recalibrated, it will actually be illegal owing to reading extremely high; 0% low & 10% high being the legal speed-measurement tolerance limits
a mistype! just 195r14c. speedometer under reads just a little
That was a MAJOR typographical error!
185 R14 <=> 185/80 R14 => rolling radius = 328•8 mm | rolling circumference = 2047•1 mm
195/40 R14 => rolling radius = 255•8 mm | rolling circumference = 1607•2 mm
195/40 R14 has a 21•5% smaller rolling radius & circumference than a 195/40 R14 tyre
Hence, if one were travelling at a true-speed of 55•0 mph, the speedometer would show an indicated-speed of 70•1 mph; assuming the speedometer was truly accurate when 185/80 R14 tyres were fitted. However, noting that the LEGAL tolerances for speedometer readings are 0% low & up to 10% high, speedometer manufacturers are likely to be aiming for a 5% high reading with half-worn factory-standard tyres; keeping in mind the speedometer tolerance changes by about 2%, from new unworn tyres with 7~8 mm tread-depth to barely legal worn tyres with 1•6 mm tread-depth.
Revving an engine at circa 4,000 rpm, when driving 195/40 R14 tyres at a true-speed of 55 mph or less, would be rather noisy and give a much higher fuel-consumption rate!
Also note that for a factory-standard 1968~79 VW 1600 Type 2 with 48 or 50 DIN horsepower engine, the vehicle has virtually optimal gearing with half-worn factory-fitted tyres, giving a maximum attainable true-speed of 68 mph, so with 195/40 R14 tyres, the vehicle would be grossly under-geared, resulting in a very much lower maximum attainable true-speed, but improved acceleration.
I should have written 195/40 R14 has a 21•5% smaller rolling radius & circumference than a 185/80 R14 tyre
instead of
which I noticed almost immediately after my post, but the website threw a wobbly, as it often does these days, which prevented me from editing my mistake there and then!
lots of detail there! i think we've been through pressure calcs before, but the stronger sidewalls seem to make a difference in side winds. don't make it perfect but certainly lessen their impact. low rolling resistance too, much easier to roll in and out of garage
Thank you all for your advice, I shall order some 185/14c tyres. Any recommendations on which brand to use?
