noddy
Its the carb vacuum combination thats important. You need to match the dissy to the vacuum signal from the carb.
If you are running one of the 30 pict carbs you should be able to use one of the 205 SVA dissys ie 113 905 205T or 205AA which is the universal replacement for the 205's.
Its should also be possible to use a SVDA but you will need to time it dynamicaly as it could be before TCD statically timed.
What carb do you have and what dissy?
