pete nice said:ET or Offset is how far from the centre line of the wheel the mounting face is in relation to the wheel. It's all about geometry, when cars are designed it's not possible to get the hubs, brakes etc directly in line with the centre of the wheel. The simple solution is to move the wheel mounting with offset. Hence a Radar has et20, so the centre mounting face is offset by 20mm, a gas burner is offset by 6mm. It really needs to be about 25-30 to make it sit right.
faux said:I'm a bit confused by this all. My Mooneye wheels have a ET +21 and there is bags of room at the rear.
Loxy said:faux said:I'm a bit confused by this all. My Mooneye wheels have a ET +21 and there is bags of room at the rear.
What width is your rim?
pete nice said:If you have an offset of 21mm, & I have an offset of 6mm, 21-6=15mm, so you will have 15mm more clearance than me to start with.
The bigger the offset the more tucked in the wheel will be.
pete nice said:If you use the MWS Fuchs in 5x112pcd they are ET6, so are the same as my Gas Burners.
pete nice said:The new SSP wheels are nice, I was there on Saturday getting my cooler.
The matt black EMPI 5's are lush, They are still cheap enough too.
If you get Fuchs, get polished ones, then detail them yourself. The detailing looks a bit strange from the factory.
pete nice said:The 5x112 gas burners are ET6, that is bad!
Clem said::?
So are ET20 ok normally?
My mate has late running gear on his 69 van and that pushes the hub carrier out. He bought some MWS Fuch copies and they would not fit on. They are ET35 (5.5")
The SSP 'new improved' 911 Fuch wheel is ET20 (5.5") .... that means it will be even worse a fit? Is that correct? I couldnt image a worse fit would exist!
I guess my pal's unused 5 x 112 'detailed' first edition MWS Fuchs are worth just about scrap value now! :lol:
Joval said:Clem said::?
Sorry, just read this ^^
I though they are the same offset as MWS *spits* and Flat4..?
