Monkeyspinner Tim
1968 Deluxe Micro bus in original Delta green paint with original Wolken white roof from California. It has very little rust and apart from the L/H rear 1/4 is pretty straight for a 40 year old bus. It has a running 1600 single port engine(not fitted) and comes with a 1500 bug IRS gearbox and fitting kit so the ratio's will be excellent for motorway cruising. it has a 67 Split bus front beam with drop spindles and 15" split bus wheels with almost new 165/50 front and 185/55 rear tyres. it has a full with rear seat and 2 seater middle seat. the rear will go down at least another inch when the engine and box are fitted and it rolls to settle the suspension. also a straight front bumper blade is included.
It needs brake work, electrics, engine and box fitting and some welding to be ready for the road really which includes one outer sill(under the sliding door) both cab floor outers and a battery tray
price is £4950 as is or £6950 on the road, MOT'd and UK registered. i can repair the rear L/H side panel for extra.
Tim. 07801949726
Mexican blankets are not included.
Tim. 07801949726
