[email protected]
- Joined
- Sep 8, 2008
- Messages
- 4,815
- Reaction score
- 95
- Location
- Felixstowe, Suffolk
- Year of Van
- 1970
- Van Type
- Westfalia pop-top
- LOCATION
- Suffolk wilderness
That’s not a bad ideaI think I'm going to weld the J tube pieces to the sled tins on mine.
Hi [email protected], could you take one or two pics directly from the underside of the oil cooler ? I plan to install a 96 rows (Length - 12 3/4" X Width -11") oil cooler as I plan to get rid of the stock oil cooler. Do you think that a 96 rows oil cooler could be installed or not ? I want to install it like you've done as I have Belly pans and I don't want to cut those.
Mines only a 72 row and that’s a tight fit, I don’t think a 96 will fit but I’ll have a measure up tomorrow. Why are you wanting to delete the doghouse?Hi [email protected], could you take one or two pics directly from the underside of the oil cooler ? I plan to install a 96 rows (Length - 12 3/4" X Width -11") oil cooler as I plan to get rid of the stock oil cooler. Do you think that a 96 rows oil cooler could be installed or not ? I want to install it like you've done as I have Belly pans and I don't want to cut those.
Ah I seeTo have all the fresh air for head cooling.
I didn’t take any pics but I had a measure up and I think you’ll be limited on space for a cooler that size. My cooler was between the chassis rails but was flat so didn’t really do anything but like I said before it was a last minute temp thing which got left. Another reason I moved it was to get the line length less, I’ve lost about 4ft in the lines since moving itTo have all the fresh air for head cooling.
Foggers? They're bleedin' funnels!!!
Thanks, I’m yet to see itThat is epic, as the article in Volksworld of your westy![]()
I like the way you used those other carbs in the background to make yours look shinier
They are cute little thingsI like the way you used those other carbs in the background to make yours look shinier![]()
Register today and take advantage of membership benefits.
