Hi I have a complete front beam hub to hub in wide 5 pcd removed last week from a 68 bus £300
71 front brake setup spindles calipers disc's pads backing plates etc with balljoints and arms £150
late split front beam very soild but stripped down no leafs etc would be good on the above brake setup if modded £150
late bay 71 5x112 pcd hubs drums shoes etc etc £100
late bay 1975 1600cc 4 rib gearbox £150 removed from a project veh not tested no leaks or damage tho
71 bay 1600cc 4 rib gearbox £170 tested before removal all working fine
all these bits are in south bristol but I can pallet the beams and box the smaller stuff
