No vid, but you can have a go if I ever meet you.
Here we go again...
This woodworking thing is not to be underestimated. If you want something square you must work to tiny fractions of a mm. 1 mm gets to look quite big when you're lining up the edge of the router blade with a line probably 0.2mm thick. Which side to cut? etc etc etc...
And Oak? It's not cheap. So it takes some time to be sure you're making the right cut in the right place. That's why it's taken rather a long time to build this damned Kitchen cabinet.
I re-designed the spice rack bit so I can have some tall things, some medium things and some short things. Then I added in the box in the top for the roller blind. In hindsight, maybe this isn't such a great idea as it's taken up a fair bit of space and it sticks out each side of the unit to span the van.
It takes me such a long time to make each part allowing for all the joints so you end up with something that has no visible fastenings. Also I have to allow for oak trim that I'm covering all the ply ends with. I've stuck a few bits on as you can see in the next pictures. If things look a bit out of line, the reason is that I've allowed for trim that I haven't fitted yet. And some is fitted but needs trimming.
Here's the pics then.
As usual, nothing but the slivers of trim is fixed. It's all jointed with tongues and plough grooves and pressed together. It holds pretty well without glue and so it should - I might have mentioned this has taken days to make the shelves and blind thing. :shock:
The blind box has to open in case it goes wrong or I want to change the material one day. This was a bit of a baffler. It's got to be strong and keep it's shape, but has to have a slot right across for the blind to come out of and I've got to be able to get into it. I reasoned access would be best though the front, but I couldn't figure a way of doing this neatly without any fixings on show so went for the top. I've hinged the top at the front and I'll screw through from the cab area behind the seats at the other side.
What a palaver! I still have to work out exactly how I'll cap the ends of the blind box.
Here it is with the flap up. It'll have 4" foam on the seat and 1" on the back so won't look quite so much like a church pew!
That's it for the foreseeable. Back to proper work next week. A long way to go with this. I still have to make drawers, runners, curved gas door, fit the blind and cap the ends, upholster seat and back, make and fit stainless cover on work surface, finish all the wood and panel behind the cooker. I'm thinking of building in mid and tweeter speakers either side of the seat back, under the blind box. and bass to the left lower down, but space for bass is limited here.
