58 special
can i take the gas tank out of my 68 without removing the engine?
58 special said:can i take the gas tank out of my 68 without removing the engine?
speedwell68 said:58 special said:can i take the gas tank out of my 68 without removing the engine?
No. It's all gotta come out.
58 special said:thanks guys, i thought so, but wasnt sure.
speedwell68 said:58 special said:thanks guys, i thought so, but wasnt sure.
Just a question buy why do you need to remove the fuel tank?
58 special said:speedwell68 said:58 special said:thanks guys, i thought so, but wasnt sure.
i am getting a panel van that has been sittin up for 15+ years and was think ing of giving it a good cleaning. or is there a way i could clean/flush it in the bus?
speedwell68 said:58 special said:speedwell68 said:Just a question buy why do you need to remove the fuel tank?
Disconnet the fuel pipe from the tank from the engine, if there is any fuel there stick a suitable bolt up it and tighten the clip. Feed the pipe back through the tinware so it is hanging next to the gearbox. If there was any fuel take the bolt out and drain it in to a fuel can. It is under gravity so the fuel flows quite quickly. Then bung up the pipe again. Then pour at least a gallon of paraffin into the tank and leave it to soak for a couple of hours. Then drain it out again, if there was any shit on the bottom of the tank this should have flushed it. Then replace all the fuel lines and the fuel filter, make sure you use proper fuel pipe clips and not jubilee clips as jubilee can go oval and cut into the pipe. Then fill the tank with fresh fuel and keep an eye out for any leaks. Any more crap in the tank should be stopped by the filter. If you can't be bothered with the above just change all the fuel lines and keep the filter changed.
speedwell68 said:Paraffin is a petrol like fuel, it is used in oil lamps and things like that. The americans call it Kerosene. You should be able to get it from DIY sheds and hardware shops...
http://en.wikipedia.org/wiki/Paraffin_oil
