Alex VW Heritage said:Loving the log burner, has ned seen it yet?
aogrady said:Hi!
Great work on the eber - will it drain the battery quick if it's 11amps? :?: A good install, cheap too, the ebers are pretty dear I think.
Will be interesting to see how quieter is is with the dynamat on the engine roof?
Great work, always look forward to your updates.
Cheers,
Alistair
aogrady said:Love this!!
How do you cut it open without blowing yourself up?
Alistair
audix said:aogrady said:Hi!
Cheers,
Alistair
It needs 11 amp at 24v to start up (or 22amp at 12v if taken before the converter). It only uses this for about 6 seconds. Then it uses 0.7amps at 24volt (or 1.4 amp at 12volt if taken before the converter) to run the fan. So on my 110amp battery it should run for a good while
Should be a lot better if you tap the panels they are dead and not a tinney noise.
Cheers mate![]()
audix said:aogrady said:Love this!!
Alistair
Remove the valve
Fill with water to displace the left over gas
Put the valve back in and cut the door with the tank full with water
Put kettle on
Have cuppa
