Myvanway
Great attention to detail again. 8)
squareweave said:Thanks for the replies. Its been a ton of work. I've been a bit concerned with how close the tie (track) rods are to the frame. So I've decided to go with a different approach and use chromoly heim joints. All of these parts are stronger than stock. This is stuff that the 4x4 guys use on rock crawlers. By going this route I can mount my tie rods to the bottom of the spindle arm giving me tons of clearance. Not cheap but I'd rather do it right. I ended up having to buy a weird size drill bit and a reamer for only four holes. The new tie rods them selves were backordered so I would go more into depth on the conversion when they arrive and I can take pics.
mychatype3 said:squareweave said:Thanks for the replies. Its been a ton of work. I've been a bit concerned with how close the tie (track) rods are to the frame. So I've decided to go with a different approach and use chromoly heim joints. All of these parts are stronger than stock. This is stuff that the 4x4 guys use on rock crawlers. By going this route I can mount my tie rods to the bottom of the spindle arm giving me tons of clearance. Not cheap but I'd rather do it right. I ended up having to buy a weird size drill bit and a reamer for only four holes. The new tie rods them selves were backordered so I would go more into depth on the conversion when they arrive and I can take pics.
Nice to use heim joints 8) i'm goint to use them also with these on the spindels![]()
http://www.speedwaymotors.com/Adjustable-Tie-Rod-Adapter-Stud-to-Heim,3333.html
Witch size of heim joints your using?
Keep up the good work love this bus.
squareweave said:I'm using 5/8" heim joints. I'm going with the strait bolt because I can then mount the arm on the bottom. Can you reverse taper the spindle arms with the size of taper the adapters from Speedway have? If not they wouldn't improve clearance I don't think.. I mocked up my set up tonight and it will work beautifully. Lots of clearance from the frame. Ill get pics tomorrow.
Lee C said:8)
The roof bars staying???
Buss69 said:Nice stance, sir. Did you paint your spring plates. I ask because I'm thinking of doing mine before fitting but wondered if the paint might cause issues when tightening everything up?
Have to say your standard of finish is a real bench mark for us all to achieve, much respect.
squareweave said:
