Hi everybody!
Hope you all had a great christmas time!?! Since my last post, I made some steps forward on my baywindow project. But all this details takes a lot of time and I'm not sure that I'm ready for next season... :lol: I will give my best!
So here some work I've made over the last few months...
The sliding door is finally mounted.
shiny!
Then I started to clean the engine bay. Under the gas tank were still some rusty areas. I cut them out and welded some new metal in.
Template for the left side
Template for the right side
Cut out some fresh metal
And finally welded in
The straps for the gas tank mounting I've made screwable. This because they were rusted and It's much easier to mount.
Underside...
Testfit the mounting straps
And with the freshly powder coated gas tank.
The holder for the air cleaner I've made also screwable. So it will be easy to install some 36 Webers on my engine later on!
After welding, I've grinded the whole engine bay. What a **** job!
Left side
Right side
And for the moment some 2K primer
The middle section of the header tube was rusted away. So I made out of 1mm steel plate my own tube. My steel roller is only 90cm long. The heater tube is around 1,2m, so I made 2 pieces and weld them together.
The final heater tube with some primer on
To mount the isolation mats easy, they all got a new zipper.
Next step was to cover the bus for the following work.
Then I've spent some time to strip the underside of the bus. Everything has to go off...
All parts on the ground and ready to clean, sandblast, zincing, powder coating and much more...
The original 14" steeles I've sandblasted and powder coated in black. For the moment I will store them in my garage. Perhaps the day will come, I will need them!
From Olaf I got some VDO-gauges for oil pressure and temperature. My idea is to install them in cans under or on the the top of the dashboard. We will see...
Wish you all the best for 2015!
Best regards
Reto
