Magiceddie88
So I'm treating my doors to a make over took off the old door panel on the drivers side, thought long and hard on insulation then saw that my drivers door didn't have anything there and figured well if its been good the last 40 years...
Might be alright to keep going that way. So anyways I POR-15'd my door where water collects in the channel, and made a vapor barrier from the original one I took out.
...stuck on the door card, well a month later I get around to redoing my passenger side. Tore into the door to find insulation! Glued good into the door with some lower wet/rot included!
My driver side had absolutely no sign of insulation...my passengers side after removing all but one patch was apparent it had insulation by the glue spots stained and stuck to the door.
So what have you experienced? Did yours have anything? Was there insulation like pictured?
Long story short I talked with the old VW mechanic in town... And hesaid it was regional/dealer option to install the extra insulation? What do you think? What do you know?
To wrap this up I got some r-rated insulation (doubled it up) and cut to fit, after POR-15 applied to the lower portion of the door I installed the insulation.
Vapor barrier next and new door panel.
Let me know what you think/ know about the insulation on doors.
-Eddie
![CDBF6696-2119-4C06-81C5-EE7A93B914D2-8518-0000068C708104A9_zps138c81f1.jpg](https://proxy.imagearchive.com/852/8525bde3b4d2caec783762951a81da36.jpg)
![4F62AB8E-B229-4AC2-8EF2-0174E8B5416D-8518-0000068C9B2E7B54_zps27c1ea03.jpg](https://proxy.imagearchive.com/445/4459772c82bcecc4ca1db604f7e10d05.jpg)
![0860F52A-93F6-4C61-B694-3BEAC1F8D9F8-8518-0000068F717D6DF0_zps6901f660.jpg](https://proxy.imagearchive.com/0da/0da004343b38964e160809e216c2c542.jpg)
![D056B22F-2196-40C8-AD7E-B1140E0AE265-8518-0000069250AAA5B0_zps5a160cbf.jpg](https://proxy.imagearchive.com/6bc/6bca33a48842d38b0a20ca42ba02f534.jpg)
-Eddie
