PSG said:Hi all
Just wondering what people have got on these as i have not got any at the moment. Cant seem to find any info and the late bayers are not coughing up any info either.
Its a dual setup for a type 4 2l engine.
PSG said:
This is the manifold and spacers. It was a dismantled running engine from a front end smash so I am sure it is all pretty much as before nobody has tinkered.
PSG said:Yeah I was unsure of their orientation, I Google imaged it. Lol.
Right, first things they are the wrong way around, the linkage is at the front of the engine, you have it facing the gearbox :lol:
Swap them around and while you are there gap the throttle butterfly to .006 using a feeler guage, once thats done fit them back on so the bowl is at the gearbox side of the engine.
You see the pipe coming off the manifold? there should be one on the other side too, link them together with a pipe and t off if you have a servo for the vacuum.
Then once all that is done, you know they are roughly balanced due to the butterfly measurements you can then tune them for idle and mixture which can be done using the small pointy screw and the larger plastic ended knurled screw.
i have turned them round. thanks for pointing that out.
