- Joined
- May 17, 2021
- Messages
- 443
- Reaction score
- 383
I noticed that my stereo that is powered off the leisure battery wasn’t charging as I can see the voltage reading on the radio. I thought this might be a problem with the split charge relay, but after checking the output of my alternator, it’s only putting out 12.8 V when I put the multimeter from the output of the alternator and the other ground. This is the same voltage that I measure across the battery. Terminals is my alternator knackered as I thought they should be at least 14 V when running (tick over)?
