Alternator
T2 Brinky
Oct 21, 2011
387
166
cardiff
Hi
On way home yesterday fan belt snapped, had a spare so put it on but alternator is now whining/howling
What’s best process for removal plz ?
Also recommended places to purchase new ?
Cheers in advance
This is the advice I got off stuff when mine died. I tried to link to the entire thread but couldn’t. I will try later but offf out. Not a hard job but can be fiddly
Fan belt off, top pulley stripped down and removed
Alternator strap removed
Remove alternator stand nuts x 4
Unscrew and remove fan housing shroud screws on the front of the housing
Then wiggle the alternator, stand and fan out of the fan housing
Pics and description are over two pages of my thread as linked above.
Not hard to do in a field with minimal tools.
Removing the alternator from the fan is a little more difficult and will require an impact driver or bench vice
That’s a great link. Some great advice. Putting it down in my little ‘threads to remember’ black book. Well.....cut and paste the ‘search link up top and chuck it into a word document’ black book 🤔. Cheers.
Alright mate, I've had one of the cheap heritage ones for a couple of years now and it's been fine. Some mixed reviews about them though. When I swapped it I did it in situ but it was a pig of a job even with twin carbs, I'd drop the engine if I ever did it again.
When you put it back together swap the alternator stand studs and nuts for bolts, makes it easier next time :)
Sent from my Pixel using Tapatalk
Thanks for all the prompt response guys
Got it off today , don’t know what’s happened to the 17mm but pulley end but it don’t want to cum off will have to find use of a bench vice somewhere tomorrow
Want to try and get it put back together for busfest
Thanks again
Thanks again
On the pulley end, there should be a notch you put a flat head screwdriver in which rests against the alternator and locks the pulley wheel to stop it moving and allow you to release the nut. Unless I have misunderstood you. :character0036:
How did the refit go? Thinking about the alternator I also bought the heritage cheap one not GSF. I also bought the buttys bits captured bolt as heritage state an original one doesn’t fit or work. I found that the original worked better than the buttys bits one. It fitted better. That is not to take anything away from buttys bits stuff which is well made and awesome.
So after how did it go??
